- Rowley, MA
Hi everyone,
I just joined and have been getting aton of good info here. I just bought a 94 waveblaster that is pretty muchall stock. It starts right up and runs strong, but is missingsome things and I am not sure what is what. I know the oil tank andpump is removed, so I just have to mix the gas myself which is fine,but I am wondering about some other things. In Pic.2 I think thereare supposed to be some kind of vents, but what are they vents for? In Pic.3 there is a hole, is there usually a choke or primer here? In Pic.4 there is a hose fitting on the carb with no hose attached,what does a hose here usually attach to? In Pic.5 some wires aresnipped off, what would these wires go to? In Pic.6 there is a hosefitting on the drive shaft bearing housing, what would this hoseattach to? Sorry for so many questions, but I am starting to go over everything on this ski and just want to see what is what before Ifiberglass over holes and what not. I plan to touch up the hull and paint it and then go over the whole motor and add new heads, exhaust, impeller, ride plate, intake grate, and probably more over this winter. If you could lend me somefeedback or even some pics, that would be a huge help. Thanks.
