Super Jet Broken motor mount fix?
I had a stubborn, rusty motor mount bolt that fused to the top threaded plate, causing it to tear from the bumper bushing when I attempted to back out the rusty bolt. Has anybody ever attempted mounting the threaded plate back onto the bumper with some kind of epoxy with success?
Those threaded tops are vulcanized on you can't fix them.This is why you use anti seize on those bolts. Most guys get longer life from couch mounts like GP800 ones. You can drill the two holes out a little bigger and slide them toward hull sides because they are slightly taller. Also you probably won't need to use any shims for coupler alignment, yeah change them all too.
Quinc
Buy a Superjet
California
What he said ^^ Replace them with waveraider mounts, new oem, or rhaas. But to fix you can clean them real well and glue it back in with 5200 and use it until your new mounts come.
smoofers
Rockin' the SQUARE!!!!
Granbury, TX
Agr
Agreed with recommending new mounts. However, there was a member on here that glued a mount back together with 5200 and it held up for an insanely long amount of time.
Quinc
Buy a Superjet
California
Agr
I believe DAG was that member. I have also glued them and they lasted until I replaced them. I run keepers, so not sure if that helps them last longer or not.
