Jarrett Simmons
Blastersc
- San Diego
Started this project with the intention of building a 1200 on a budget but poop happens... I have done the 1200 conversion before but went off to school so sold it.
I started off by buying a blaster that had a b pipe, buckshots, and a newly rebuilt 701. Rode the ski once and the engine ripped but parted it out and got more than the price of the blaster for the engine and parts.
I then bought a gp1200 with a 175 hours that came with a trailer for 2000. Parted out the pump and excess parts and sold the the trailer to make up most of the cost of the 1200. The 1200 started at idled fine, however once i started riding and came to a plane the engine would cut off. I would then have to restart it and then it would run then die again. The pistons and cylinder are in great shape. The battery seemed pretty weak and eventually died after restarting the ski so many times. I got a carb rebuild kit thinking that was causing the ski to die. The ski also wasnt getting gas when i tried starting it the next day on the trailer. Any ideas?
Removed all the foam in less than an hour
Ive begun prepping the ski for paint. Still deciding on colors. The last ski i painted came out great but thinking of trying some new colors
Last ski
I also bought a skat trak 16/23 for the stock pump and painted the pump with some protective textured paint. I got it off ebay for 150.
I also ordered an ada racing conversion kit. Next thing to be done is to have the 1200 waterbox cut, shortened and welded. I plan on modifying the gp1200 exhaust outlet.
The ski came with a custom steering stabilizer set up so i will need to make something custom in order to utilize the 1200 steering cable.
Does anyone know if the gp1200 stock airbox will fit in a blaster?
Sent from my SM-G925V using Tapatalk
Last ski
