Buttoning up 701 swap on a Superjet, looking for help misc stuff
BombThreat
'Diggity
Johnstown, NY
I was wondering if you guys could help me out with a few things. I need some info on the following for a 701 62T swap:
-Fuel line routing/diagram
-Stock water cooling routing (stock everything for 701)
-Dual 38's Factory Tuning needles specs
-How do you connect a aftermarket primer (hose routing). My Sj came with one for the single carb and I also forgot how those hoses went... Primer is the push/pull type
-Is there any special mods to make the dual 38's F/a work with the SN hood? One of the air tube inlets is hitting the f/a cover not letting it shut.
Thanks guys!
