Cable tie points on superjet broken (help)
The little metal brackets that you can put zip ties on to hold up fuel lines and exhaust hoses inside my superjet have broken. This leaves my exhaust tube laying on my battery which is not ideal. Is there any other way to fix this.
Alabama
I have been replacing mine with a cutoff piece of 3/4" square aluminum tube with hole drilled in it for the rivet.
I just file it smooth and rivet it in.
Usually there is still enough of the plastic right close to the rivets with a little slot, you can still get a ziptie in there you just may need to get a small flar screwdriver to open the slot up a little. I'm pretty sure all of mine are broken off now but I have been doing this with the remains and getting away with it for years now.
