Zero Client
BeerrroooOOOT!!!
- Douglasville, GA
I'm trying to get my head-dome size correctly spec'd for C12 race fuel and need to know the best most accurate way of determining over-all CR for the fuel. I need to know if most calculate from the bottom of the stroke (IE full stroke aka 68mm for stock stroke), or from the top of the exhaust port.
When I put on my mathematical hat; I'm coming up with a CR of about 15.5:1 measuring from full stroke, but I also understand that's more the dynamic CR, while the static CR based on my calculations are more like 7.5:1 from the top of the exhaust port.
So - which is correct? I know basic cranking would probably be closer to the 7.5:1; but with exhaust tuning/backpressure and the natural 2-stroke 'super-charging' effects, the higher CR comes into play.
c12 fuel is rated for CR below 15:1.
Pump gas is debatably rated for CR around 12:1
