Other can i change my 62T carbs to a 61X
Can i put my stock 62T (04' RN) carbs on my 61X (93' Blaster) setup?
is it possible would there be any modifying required?
any possible performance losses in doing so?
Also can i put my ADA girldled head on the 61X set up that i previously had on a 62T?
same questions as above.
thanks, jd
IMO don't go through the trouble to change the carbs not worth the gain...do you have an enhancer,bored nozzle and b-pipe for low end hit ?
not really looking for gains. the single 61 carb has issues and rust. i just replaced my carbs on the 62 setup and was hoping to use then rather than have them as a paper weight.
dfw
The trick is to find a dual 38 61x manifold. I have found 61x manifolds for Keihins and Mukuni 44s but nothing for Mikuni 38s.
