Polar Bear
X-
whats the difference between a 701 motor, 760 motor, lamey motor, 61x motor, 62T motor etc. etc.???? I see all these numbers and names but have no idea what they mean. is one better than the other? thanks
Polar Bear said:so if I have a 96-98 701 superjet with dual carbs, it will have a 62t case and 62t cyl. which is o.k to turn into a sick power plant? and how do i go about tricking out this engine? sorry for the stupid questions.....
It will have a 61X cylinder. 62T cylinders only came in sit downs. Read this forum every day and you will learn how to trick it out and make your wallet thinner.Polar Bear said:so if I have a 96-98 701 superjet with dual carbs, it will have a 62t case and 62t cyl. which is o.k to turn into a sick power plant? and how do i go about tricking out this engine? sorry for the stupid questions.....
robertg said:Read this forum every day and you will learn how to trick it out and make your wallet thinner.
2nd nature said:im broke to but got some bad ass parts
SJKny said:In stock form...........
701 = 61x cyls.
760 = 62t cyls.
61x cases = single carb
62t cases = dual carb
Anyone care to explain how to tell the cases apart?
Great thread... suscrib'd. :biggrin:
