Can you I conformation on fuel selector.......
For the fuel switch, left is on, up is off, and right is reserve? The sxr I just picked up is painted and the stock markings for the fuel are gone. Thank you for replying.
Okay, so I messed with it today. It points, left, down, right. I'm guessing right is on, down is off and left is res? Can these be put in upside down like that? I just bought it and its a fully built ski. 1100 yada yada paint so it's been completely apart. Thank you for the help
Andy, left is on, up is off and right is res. and yes the knob can be installed upside down, just unscrew the little screw on the side of the knob and flip it around and reinstall the screw, the best way i use to remember is that " up is off" if its pointing left or "in towards the ski" then its picking up fuel from the main fuel supply and if its pointing out or right then its taking fuel from "outside of the ski" realistically meaning from the smaller fuel supply hope this helps ;)
