Super Jet Can you run 701 electronics on a 650?
So i was wondering if its possible to run a 701 ebox with a 650 motor? im picking up a hull with a 701 that needs some refreshing and i have a good running 650 in a hull that i want to mod. So is it possible for me to just pull the 701 and plop the 650 in there and let it rock tell i get the 701 ready to go? anything i would need to do?
thanks for any help,
-Jesse
Yep. If its a dual carb 701, you'll need to run that flywheel, too
ok sweet, so just pop the 2 flywheels off and switch them and i should be good to go? what happens if you dont switch them? just curious.
anyway to tell the 6m6, 62t electronics apart? and is there any benefit to running the 62t electronics with the 6m6?
thanks for the help,
-Jesse
Why don't you just run the 650 electrics with the 650?
Im buying a nicer hull then mine with a 62t in it that needs some work, and i have a good running 6m6 in my hull now so i could just swap the motors, i sapose i can witch the electronics too, just thought mayber it would be a little easier or possibly better in some way? lol hopefully it wont be to long and ill have the 62t in it.
thanks for the help!
-Jesse
-Jesse
It would be more work to run the 701 electrics in the 650 than it would be to just keep everything together.
