I have a set of Mikuni 46mm carbs. The Flame arrestor side has a opening of 51mm. Was the taper bore normal for a year range, or were these Mikuni carbs modified by another place?
Are your fuel input and return fittings 90 degree fittings, and are the carbs silver? That would tell you they are AM Mikuni vs OEM that came on a ski, but they were almost certainly taper bored by somebody
