- Saskatoon, Saskatchewan, Canada
I have just put on some 46mm buckshot carbs and i cant seem to get the ski running again. If the ski is out of water as soon as i start is (prime it to start) the engine races to WOT with out me touching a thing. When i put it in the water the only way i can get it to run is off the primer, as soon as i touch the throttle it dies. So i figured it was getting too much fuel, But when i drained the fuel lines and started the ski it ran decent for a bit.
I have gone throught the cabs and they are clean and free of any debris, and the jets move freely. I blew through the lines and they are clean.
I was thinking that maybe my pilot jets are too small so i have to pump the primer to get enough fuel for it to stay running, but as soon as i give it throttle it leans the mixture out too much to run. Does that make sense?
I am running a polaris octane with:
High compression pump gas domes
Dry pipe
aftermarket cdi from watcom
135 main jets
70 pilot jets
Any thoughts on what else it could be?
Dry pipe
135 main jets
70 pilot jets
