Just finished my superchicken rebuilt and have 404 left !You could also just use a good epoxy with filler in(like west system 404). im pretty sure Xscream uses normal epoxy with filler material for case filling. And not Aluminium epoxy.
Yeah i know what 404 is ! Just dont know which resin hardener to use it goes from 206 to 209West systems 404 is the filler poweder to add to the mixed epoxy resin.
I use Easy composites epoxy and then put in the 404
404 High-Density Filler | WEST SYSTEM Epoxy
WEST SYSTEM's 404 High-Density Adhesive Filler is an epoxy thickening additive developed for maximum physical adhesive properties.www.westsystem.com
