- San Diego
So, I was waiting on parts at one point and decided to finger port a case. I think I made a big mistake. I was going to leave the engine stock except for bolt ons for reliability but had idle time and this is what happens…my question is this: can porting cause an engine to fall on its face around 6000 rpm once it’s hot? I know that I have altered the case volume which will impact vacuum and compression in the entire engine, and now that I think of it would likely cause the pulse signal to not be as crisp. Is that what’s happening? This is a second case that I’ve molested, I’m realizing now that when I ingest water I want it to hit all these surfaces and vaporize before it hits my piston and rings. It’s power vs reliability and since I’m always chasing big air in salt water- the colder the better, I should be prioritizing reliability. So, how bad have I messed this case up? I plan on going back to the stock upper half on my fresh sp today but it has some damage where the FPP limited chamber was rubbing. What are thoughts on this? Any advice? I wish now that I had asked these questions here before getting so far into it.
