- JAX FL
More time on my 50cal and I am starting to realize when I land a lot of my stuff the ski either wants to cat walk a lot or it does not want 2 hook up fast enough to recover even though the engine is turning good RPMs. Engine gets up to rpm ( no bogging,) it just does not get the bow down. I can lean way over the pole dig a knee into the firewall but it still cat walks and I spin in circles. Running a set back 148 mag 7/14 cut back with a ported 701 61x dialed to perfection and then some. Ski hits really good other then during my landings. If anything I would say the prop is spinning and not grabbing enough water. I removed the Intake grate and that helped a little.
So my question is..what direction should I go with the prop?
Any other advice would be great.
