- virginia beach
Hi all. I need some help.. badly!!! I got an older x2 (I think a 90.5 seeing how it has the direct steer system) for free. It has a westcoast waterbox (I think), a tunable pipe, oil injection delete, CDK ii 42mm carb and aftermarket intake manifold. The ski was put up about 10 years ago but everything was drained properly at that time. Now it won't start.
After new plugs, gas, fuel lines, cooling lines, etc... It turns over like a champ and has plenty of spark and compression. However, I cannot get it running. I just rebuilt the carb with a new Fuel Dynamic kit. I didn't touch the hi or low screws or the ree ds at all, but replaced everything else. I was left with a single o ring, one main seal and a small flapper valve (I am guessing this because this kit was for multiple carb versions).
This was my first carb rebuild and replaced everything as I found it so I was surprised to not see gas dumping down the carb throat after cleaning it all out. I tried to hold a pice of paper on the fuel inlet (the lower one on the carb) but I wasn't able to see if it was sucking or not. Also, I never saw any gas go down the throat or come out of the brass rod that goes across the carb throat area.
Could this carb be trashed? Do I need to do something with the hi and lo screws? Could the reeds be trashed and therefore it isn't creating enough vacuum to pump the gas?
The pics of the carb are attached.. any help would be appreciated!!!!
