OEM SEALS ONLY
do it right first, or do it again during the ski season!
Don't put em in backwards
if you ever have to change crank seals during the season. don't tear your engine down just flip it upside down and pull the bed plates and bottom case, lift crank, change seals, and realign the bearings. put yamaha bond between the cases and retork. quick and easy.
