So i am changing out the stock impeller, im getting a skat 9-17 impeller...when i change it out do i need to replace the wear ring or pump housing, or can i just change it out with no problems, thanks :laugh2:
As long as your clearances are good you should be fine. If you have some major chips in the veins or blueing marks in the wear ring where the impeller would be rubbing i would consider changing out the pump.
