cheapest bars
Who makes the cheapest 0 degree bars for an sj? I don't mind spending $70 plus on bars for my quad but on my sj all they'll ever hit is water
FlightPlanDan
Don'tTrustAfartAfter50
Stock turn plate?
You should count on your ski-bars taking as much abuse as your quad.
Water is easier on your body, not so much the vehicle!
Riva sells a heavy duty "0" degree. (not straight). will fit most turnplates.
:stups:there used to be some 0* bars on ebay in the kawi section that were all cut, bent, and powdercoated at the same shop for 20 bucks. but i do not know if they used a thickwalled tube or not. if you insist on useing a cheap bar make sure you keep the stock rubber pad on it so when it smacks you in the chest after it breaks it wont hurt as bad, mabey you wont even crack a rib.:stups: buying some used is your best bet to save cash.
