I just took the old ripped vinyl off my 750sx chin pad and cut the foam down to make a little less obnoxiously large. But what kind of material can i/ should i cover it with and how?
Any marine vinyl will work just fine if you want to put another cover on, if you can get the 4 way stretch stuff it will make your life easier to cover nicely.
just got it done, ill up load some pictures tomorrow, didn't get it very smooth cause i got impatient but it beats spending $60+ on a used one and you learn a little something from it=D
ok, so now I took the bar covers off and I am attempting to upholstery them to no avail. I have tried weldwood contact cement and loctite 300 spray adhesive but niether of them held well enough to keep the vinyl tight around the corners. I might be doing something wrong aswell, any ideas?
Heat will make it a LOT easier to stretch and it won't pull at whatever glue you use. I used contact cement on the tight corners and heat to pull the vinyl in
