1994 Yamaha WaveBlaster 1
Originally Blurple, painted with a very high quality lime green finish. Carefully rebuilt from the ground-up with stock and quality aftermarket components. This is a great ski that has been a ton of fun to ride over the last few years. Moving on to other interests.
Stock pump with Hooker 10/16 prop
Ocean Pro ride plate
Scoop grate (unknown brand)
701 Industries Suspension Steering
WaveBlaster 2 steering cable and ADA cable bracket
61x 701cc engine freshly rebuilt - 0 hrs
JetManiac welded and trued crankshaft
New crank seals and gaskets all around
Jugs measured out to factory specifications and rigid honed
New RIK piston rings
150/150 psi compression
MSD Enhancer cdi
JetManiac positive and negative battery cables
Jetmaniac Yamasaki ignition coil
New AGM battery with 1 year warranty
Billet aluminum finger throttle
Stock SBN44 carb ultrasonic cleaned and rebuilt with Genuine Mikuni parts
T-Handle high speed adjustment screw
New (1 season of use) OEM stainless reeds
Clean fuel tank with newer lines, check valve, strainer, filter, and primer
New OEM fuel selector switch
Oil injection delete / pre-mix
$4,000 OBO.
Ski located in North shore Massachusetts
Pickup only
MSD Enhancer cdi
$4,000 OBO.
Pickup only
