I always blow out the exhaust before leaving the lake then again at home. My SJ blows dry the first run at home but I still get moisture out of the sxi after 5 or more runs. It won't shoot water but I can feel the moisture on my hand and see trace amounts on the ground. Seems that I can't get it to blow 100% dry. Is this typical? Is there be a pool in the water box causing this? Is this enough moisture to worry about over the winter or do I need to run again and again and again until it's totally dry?
