Complete Carbon Circus w/1000
East Coast.
Must sell ski. October I became a paraplegic due to a motorcycle accident. 4 year/season on this monster. Carbon Circus Built by Tem with no cracks or issues. Has scupper and single bulge pump. Has all the goodies you should expect. SJ base with Jetworks 10 mill ADA 1000 top end. Runs on AV gas currently. New MSD total loss with only a couple tanks on it in sealed box. RRP carbon exhaust, And pole. I think it’s Thrust riser steering. Full spec 49 carbs. 155 pump with deep grate to grab extra water. Thrust trim. Custom turf job is in excellent condition as can take you kicking at it anywhere. To much to list and can’t even recall As the ski is in friends basement for the winter months. Only thing I would recommend is a couple new OEM tank tie down straps. These are getting a little soft. Also since I’m getting out of the sport I’ll give you boxes of other parts, bolts, and everything else I can find. First $12,000 takes it. Located in Maryland. Plenty of power for back to back flips or other combos - will see if I can upload videos.
