- Fort Mohave, AZ
Blew out a rear crank seal. Upon disassembly I noticed the crank is super noisy, especially the connecting rod bearings. Both rods have several bearings with stress "fractures". What causes this? High compression, age?
Yup do that every time, few braps in the parking lot, and a few more at home. I'm wondering if these were there when I bought the crank (used) and just got worse over that last few seasons.View attachment 441788
And try clearing out the water box after you take your ski out of the water and again when you get home.
I've been running Maxima 927 since 2009. Hoods always come off once home. Engine bay is usually dry within the hour as the outside temp is usually 110-120⁰ and about 10 percent humidity.Use TCW3 oil and get the engine hot on the trailer before you leave the lake and again when you get home. Almost no jetskier does this thoroughly enough, thats why almost all cranks out there are rusty. Make sure you store it with the hood cracked open. Unlike an outboard, our exhausts and engine compartments hold water so extra precautions are needed to prevent corrosion.
My only run by me SXR crank was still super smooth bearing wise after 1200 hours. There is no reason to get the engine hot at home again.... I blow out my water box on the trailer/float after running it.Use TCW3 oil and get the engine hot on the trailer before you leave the lake and again when you get home. Almost no jetskier does this thoroughly enough, thats why almost all cranks out there are rusty. Make sure you store it with the hood cracked open. Unlike an outboard, our exhausts and engine compartments hold water so extra precautions are needed to prevent corrosion.
I'm going with the bearings bad before you installed this crank.I've been running Maxima 927 since 2009. Hoods always come off once home. Engine bay is usually dry within the hour as the outside temp is usually 110-120⁰ and about 10 percent humidity.
Different ski than in the photo. This was out of a superjet. Newmiller machining head, just tested it after the seal popped at 180psi. Has a MSD enhancer module. I use the SJ mainly to chase my wife around on her STX15F.While water ingestion and corrosion play a very large role in crank failures.
if you popped the rear seals out ? Your crank has developed fairly large deflection.
this is from wear. High compression, excessive timing advance. Lean - high rpm running, and water ingestion are all leading causes.
as suggested, running quality 2-stroke oil will give longest service life. High compression, and excessive ignition timing work hardest at shortening life span. You need to find the performance balance to fit your riding objectives. Judging by the ski photo in your avatar, you live for high comp and strong timing to do the tricks your after. Sorry to say, its the name of the game.
for discussions sake, what is your comp? What ignition? And about how old is your crank? Is it a stroker?
P
That's what I'm thinking. Used crank, I just tossed it in when I built this ski.My only run by me SXR crank was still super smooth bearing wise after 1200 hours. There is no reason to get the engine hot at home again.... I blow out my water box on the trailer/float after running it.
Even running Amsoil Dominator, which is NOT TCW3 rated(probably exceeds it by leaps and bounds), my crank was oily when I took it out. I had the perfect little patch of oil that drained to the bottom of the case as well. I did not find any signs of corrosion or rust. Riding in super humid Wisconsin Summers, or freezing temps with condensation.
