As some of you know I am taking computer programming in school, and we have a web/design project coming up that i thought i'd use as an opportunity to setup a nice tuning/jetting web app. If it works well i would consider pushing it towards a mobile based app for android and possibly apple, but for now it should start simple. I would like it to data log information inputted, disregarding excess (+/-X%) of the mean values for those that want to tell it their 650 has 210 main jets on twin 50 blackjacks... :|
It would possibly pull in the following info:
~Carb size
~number of carbs
~flame arrestor (Maybe AM/Stock)
~bore (mm)
~stroke (mm)
~dome CC
~reed type (rounding up values for carbon/fiber vs stock) (this would probably not be in the alpha build)
~case type (maybe)
~exhaust type (difficult to firmly calculate values for these)
~porting. porting to specific companies would be difficult to accurately calculate. This i may just make an option of porting or No porting and change the values by X%. (sorry no option for "freestyle porting/jetting" alex).
~decking and squish would not be included to start, but could be added fairly easily.
~flat top vs regular pistons i would leave out
The alpha run of this will probably use a stock 61x, 62t , 64x, etc as baselines (as per yamaha), it would handle up to triple carbs. I'm hoping to use this to aid in the struggle of those who are new to the sport. I'm hoping it could get them on the right track sooner. Obviously its not going to be perfect, I will probably leave screw turns out of it for the initial run, and see how easily adding them in would be later on.
Ill host it on the school server while i can, and then could load it elsewhere if it becomes popular. Probably wont see anything up and running for 3-4 months, but we shall see as i have free time.
CRJ
~Carb size
~number of carbs
~bore (mm)
~stroke (mm)
~dome CC
~case type (maybe)
CRJ
