Midlake Crisis
- Bakersfield, CA
Anyone used this particular stuff to install turf or lifters?
A ton of people use it. I've heard its what hytroturf brands as their glue. I know most will say to get the red black can. Not sure what the green is, but as long as it's not water based/soluble, you should be fine.
Do not use the green can ,the stuff is garbage .I've used it before and it would not stick .:chairshot:
Meaning if you use the green can, water will start to dissolve the adheasive.
Or you could just get a Splash Guard for your ski...:burnout:
