Super Jet Cooling system check
Just wanted to make sure my cooling setup was OK. I have a 760 with a b pipe and dual cooling. OEM cooling line goes to bottom of manifold and both outlets on the head go to pissers. The second cooling line goes to bottom of headpipe and second headpipe fitting goes to a T which goes to stinger and pisser. Does this sound OK? Do you want the headpipe cool and the stinger hot?
Yep sounds good. You want the headpipe at a consistent temperature (cool is good) and the temperature in the stinger doesn't matter so much.
