- Floridapunk
Coosa board, Coremat, Nomex honeycomb, closed cell foam- upper hull choices at sandwiching a core material?
interesting, raw material, prol a little heat and a fixed positionthermoformable
Mister Ho does no such thing!I believe the idea behind the Coremat is it creates basically an I beam between the layers of glass , carbon or whatever.
The expanded PVC is basically very closed cell foam board , the shiny finish on it has to be sanded with at least 80 grit to create some tooth but I have repaired many things with it, I have never had one come back.
