I need a pic or diagram how the fuel cables are routed arounf those plastic wheel on a sx 750. The cables that turn the gas on and to reserve. If somebody could help me that would be great. Thanks
On the "Wheel" it's written "OFF - On - RES". On the wheel the cables overpass each other. I mean you install the RES cable in the "On" side hole, and the ON cable in the RES side hole by overpassing each other.
Well I got that because thats what i took apart first and I paid attention to that, but it came off the wheel on the dash side and the only way that it will pull the fuel selector correctly is to actually cross the lines on the dash wheel, but that doesn't seam right cause you can feel the lines rub.
