I'll be honest with you, I originally wanted to just returf but I convinced myself since that since I had the turf off I was going to install holds while I was at it. Prior to installing holds, I had absolutely 0 fiberglassing/epoxy experience. I didn't go for top of the line footholds, but now that I look back and honestly everytime I ride, I realize that footholds were the best thing I've ever ever done to my ski. Oh, and as far as returfing.. You don't want to rip off and returf, just put in the footholds now while you're at it
Edit: I was very hesitant and worried I would mess things up, but it's not that hard honestly. Just make sure you search the X for installing footholds and returfing until your eyes are sore and you've got a headache. Then, everything will be a breeze! And if you mess up, don't worry that much, fiberglass is extremely strong and can cover up your mistakes.
I actually enjoyed glassing my holds.
Good luck!
Edit again!: I highly recommend turfing something else before you turf your tray. In my opinion, turfing was A LOT harder than installing the holds. I turfed my fire ext. first and that really showed me how turf works with heat. Also, make sure you spend alot of time measuring your turf and leave some excess to trim. If it's your first time turfing, I'd possibly recommend ordering two sheets of turf incase you mess up.
If you've got any questions, let me know, I'd be glad to help. Oh, and the two part foam is very amusing to see how much it expands, just be careful because that crap doesn't come off of stuff easily. If it dries on your skin, it will not come off until you shed/grow a new layer of skin. I had to use 60 grit sandpaper to sand it off the palms/fingertips of my hands LOL. So, USE GLOVES! And tape off anything you don't want the foam to touch.
