this is what they looked like the night i got home with them.both bottoms are beat up pretty bad. the rn has holes in it. the sn holds water. lol. cost me a motor as it was sunk with rain water when i pick it up. the rn was saved from the same fait due to the holes in the bottom. i have tons of sn superjets so no rush redoing this one.(good winter project).
pulled the pump plate,grate,pump shoe was broken so i choped it out. going ot have to pull the motor cause the hole is pretty big and will need fixing on both sides. zero tubbies are going on this one. the motor has a riva dry pipe riva head. it starts and sounds good. still going to tear it down see how used up it is. new motor mounts. going to put some footholds. not sure whos yet. anyone got info on a fixed stear boat at what holds work the best or it dont matter?
