Crank bearing locator pin questions
BruceSki
Formerly Motoman25
Long Island
So has anyone ever come across some cases where the previous mehanic/owner/whoever didn't install the crank correctly on the locator pins?
When cases are torqued, the crank bearings press the locators into the cases rendering them useless. Just curious if anyone has an easy fix for this.
OCD Solutions
Rentz, GA
Use the same methods as what it takes to remove a broken bolt.
Wasn't there a similar post to this last year but the pins ended up busting out the backside of the cases?
Pablo
sqeez bth levrs & lean bk
georgia
Although crude, this worked. I was faced with either trying it or trashing a set of ported/epoxied cases. So, I triangulated the pin position with a micrometer and marked the same location on the other side of the pin. Drilled down to it with a press. Tapped out the pin to desired height and back filled/sanded the bore hole with Epoxy putty. Worked like a charm.
BruceSki
Formerly Motoman25
Long Island
I guess you were the one with this problem last year. I recalled the post OCD mentioned but couldn't find it in a quick search. I'll see what I can do tomorrow after work.
Pablo
georgia
Supertune/chuck always had the most well written informative posts. Too bad he doesn't post here anymore.
I've thought that a 100x's. Douche bag know it alls that chime in and contradict his advice used to pizz me off to no end.
Norass411
Hoarder
NC
I would pull them by welding as per your plan and then attempt to source/make longer pins. Check factory height above the cases and add that to the depth of the holes you've got.
Sent from my SM-G900V using Tapatalk
BruceSki
Formerly Motoman25
Long Island
Front pin went through the cases. Quick fix with the tig.
Rear pin pulled right out with the mig welder trick.
Now to find some replacement pins and put it back together with a fresh crank.
