Crank seal grease
Pa
Is marine grease ok to use to pack the crank seals? And is it good for the mid bearing? Or should I be using a racing high speed grease? When I did crank seals before I used maxima marine, but I’ve been told I should use a racing high rpm grease
Pa
Also when assembling bottom end, just sealant on one case right? And can I wipe any excess that squeezes out
smoofers
Rockin' the SQUARE!!!!
Granbury, TX
Yes, you only need it on one half and a very thin layer. I'll usually spread it around uniformly with my finger.
