Custom Deck JS550
Just got done with my js550 and boy was it fun. Somewhere along the way I picked up a 750 and an x2 so I have been busy with that as well. If you want the story, heres the link:
http://www.pwctoday.com/f72/js550-build-first-attempt-259973.html
While I was doing some hull hacking, I did a few differant things. I filled in the fuel filler in the front, glassed over all holes from front exhaust and pisser, and converted it to rear exhaust. I also did all the powder coating. Almost all engine parts, brackers, ride plates, you name it, were powder coated by yours truely.
If you want to just see pictures, here they are:
Heres what it originally looked like. Driving it hom from San Diego
Pwgsx
Go big or go home
DFW-Texas
very nice, similar to mine but I got a stock engine but I did re-form the hood vents. I would look into a better hood strap as the stock one is crap and may let go. :)
Yup I did paint it myself. Its a acrylic enamel paint that was very easy to use. Unlike your standard base coat clear coat, it is a one step spray that you keep spraying untill you have your desired flow and coat.
Pwgsx
Go big or go home
DFW-Texas
What kind of primer did you use and where did you get the paint from?
steve-uk
Manners cost nothing
Barrie - ontario
that looks mint... i always hated those 550 front exhausts... looks like the breather from a furnace....
what tank you running? looks like a jaz maybe?
N2 H2O
Previously Tbone550
Charlotte, NC
That's a clean 550. That's a pretty neat idea to just cut the walls in the back.
I recently got a js550. I am looking for a finger throttle for it, where did you get yours? Also, what modifications do you recommend?
You can get finger throttles a lot of places. I order a lot of my stuff from Optima Racing or Blowsion. I would start out by getting a pipe, impeller, head, rideplate, and bars and finger throttle. Also, If you have any more questions about your 550, start a new thread in the 300/440/550 section.
