Need some advise on cutting back 13/17 concord for superjet.
There is a washer at the back or the prop.....do i still use it or junk it?
Can i machine the 3mm of the shaft shoulder to set the prop back?? or do you have to machine the 3mm or the prop face that butts up against the shaft shoulder?
Either way the prop is being moved 3mm back towards the pump.
Do i junk the washer and cut back 3mm?? or keep washer and cut back 3mm.?
