How much clearance is needed between the outside of the bottom of the sleeves and the cases.
J justride Guest Mar 7, 2006 #1 How much clearance is needed between the outside of the bottom of the sleeves and the cases.
T-bone brraap....thats so 2002 Mar 7, 2006 #4 just remember this rule "slide in, good....hammer in, bad"
jetskier79 I'm goin' for two Location San Diego, CA Mar 7, 2006 #5 T-bone said: "slide in, good....hammer in, bad" Click to expand... Hmmm...my moto has always been, "if it doesn't fit, get a bigger hammer." Should I change that?
orange flattop freestyler The Carlsberg ski Location Essex UK Mar 7, 2006 #6 You should leave minimum 0.25mm clearance all the way around, this is to allow for heat expansion.
