I have a Superjet who is running very lean on Cylinder number 2 , if you look at the pictures you will see that the number 1 is good and the second one is very lean , when I did my testing , my low speed reading was good on both cylinder ,but when I go from mid to high the reading , it is very lean on the cylinder #2, the pictures are the mid rang reading, it is worst on the high speed reading
My set up is 135 high speed jet, stock low speed jet, stock Needle and 80 gram spring, the starting set up was low speed screw open 1 1/4, high speed open at 1 turn,
But now the rear carb of cylinder # 2 is 1 1/2 high speed screw and low speed is at 2 1/4, front carb or cylinder #1 high speed screw is at 1 turn and low speed is at 2 turns
the B-pipe screws
bottom is close
the middle open1 3/8
the top open 2 turns
I think the crank seal might be the problem
the B-pipe screws
bottom is close
