Currently I'm running a 44mm carb, 61x/61x setup with a limited b pipe, 180 compression(yes I know it doesn't effect tuning but it does make it run hotter, correct?), dual cooling, etc.
Right now I'm sending my cylinders off to HPE for exhaust porting and the transfers to be cleaned up/matched. Yes, I have talked to him about tuning changes but he said he rarely does anything with 44mm carb setups and said if anything, I'd maybe have to go up a size on the main jet.
With my current setup, I'd say if anything it's a tad rich but rips pretty hard. 145 main 120 pilot stock n&s and 95g spring and only one screen on the spark arrestor.
On my new hull, I'll be swapping out to 33 domes and my hull will be 30-40 pounds lighter than my current hull and my new hull probably won't endup seeing a ton of WOT.
Where should I start? Does porting change your tuning drastically compared to the typical b pipe setup? Because from what I understand, the standard b pipe jets are actually a little rich to begin with. IDK how many turns my screws are out right now but if absolutely necessary I can check that later. I don't hear of alot of people running a 61x/61x single carb 44mm with freestyle porting so I thought i might as well ask around..
Thanks aheada time!
Thanks aheada time!
