Freestyle Dasa 12mm x 89mm cooling lines
Hey guys, Im just running this motor with B pipe and Im a little confused about the 4 fittinhs on top of the Dasa head.
My past motor I just ignored and just used 2 but I was adviced to run all 4 on this one.
Since the Factory B Pipe is very sensitive to water flow, I want to hear some tested options.
I did dual colling to exh manifold, 1 line from head to headpipe and all 3 going out.
As it is a all billet motor, colling must be very accurate.
Lmk any info.
Tks
Gera
SuperJETT
none
I'd split the dual cooling so you have a dedicated motor circuit and a dedicated exhaust circuit. That way, you can tune each one properly without affecting the other.
Contact DASA for proper engine temps to shoot for.
Hey SJ.... I did that in the past when ran Speedwerx pipe. That's a cool option.
I spoke with Kyle @Dasa and he gave me an advice about it.... the lines are crazy.
Gera
Gera
Hey can you help me with how Kyle told you to run the cooling lines? I am running a 8mm Dasa 950 on a B-pipe with duel cooling and am trying to figure out the best routing...
Cant remeber exactaly but I ended running my setup as major guys...
Let me know if you want me to write it down to you.
