Custom/Hybrid Dasa 850cc ring end gap help plz
2016 Rickter Edge
Blowsion Built.
Dasa 850cc SS 89.5 mm bore (fresh)
Piston clearance .0075”
Piston ring end gap .041”
Pistons kit purchased from Blowsion. C/o dasa. C/o wiseco.
Parts numbers match up
Piston rings re ordered. In case of fluke after speaking with Dasa. Same exact piston ring clearance
Pictures 3520 KD rings being used with a 89.5mm bore piston pictures attached.
What should I do?
I have double checked and triple checked bore tolerance with a bore mic. I actually had multiple professionals outside the company who performed the work check tolerance
I need a solution
