I have a DASA 900 10mm stroker with Power Valves that is on the original bore with 195 and 198 psi. Motor has seen only a couple of tanks of gas per year for the last few years.
Factory pipe, exhaust manifold (still on motor) clearanced to fit the power valves with Jet Works flow valve. All screws work. It appears to have had a repair that does not leak (I was not aware until I pulled it from the ski).
MSD TL ignition with fly wheel (still on engine).
148 mm pump total pump assembly with trim.
Full Spec 49 carbs
Would like to sell as a package $5750 Motor Short block $3000, pipe $750, carbs $750, pump $850, TL ignition $750.
Darrell 734 386 6657 Michigan
Full Spec 49 carbs
