There's no real bad side to those engines you mentioned. Just a matter of what kind of power you want. The +8 crank is going to be a harder hitting motor, but the stock stroke motor is going to be a smoother drawn out power curve. The stroker motor is probably going to cost you a bit more, as new stroker cranks start at $700 I think for an ADR. Stock stroke cranks are only a couple hundred.
