Dasa motor help
Hi guys
is there a certain way of setting up stock electrics on a DASA 970 10m stroke
my set up is
dasa 10m stroke
novi 48
powerfactor pipe
v force 3 reeds
msd enhancer
lightweight stock flywheel
its in a blaster 1
its starts but it sounds terrible
any help would be much appreciated
thanks again Paul
Roseand
The Weaponizer
Wisconsin
Is this a fresh build or something that was running properly before? Shouldn't need to change anything when running stock electronics. Is your stator oem? We need more details
I got this motor from Blowsion in 2018
i was running an atp flame TL in a carbon wave raider
so the wave raider is gone so is the flame TL
its been sitting on the shelf 3 years
so I have this blaster 1 and I want to put this motor in it
and I want to run the stock electrics from a 62t
i have a question the DASA motor has 62t cases
do I just line up the stator plate on the timeing mark on the cases or does it have to be moved
thanks paul
You can put stock ignition on any motor but performance will be less for sure. Heavier flywheel and you'll lose throttle response snap. Colder spark and worse timing curve decreases power too. I've got a couple Dada 1000s with enhancers and light flywheels and they rip pretty good
Hi guys
would you have jetting specs for
lamey cylinder 8m no powervalves
powerfactor
48 novis
boysen reeds
compression 200
atp flame tl
thanks guys
