- orlando,fl
Ok, im not sure what to do next. First i had a starter that went, and it seems at the same time i had a solenoid go. the starter would not disengage, replaced starter, and replaced solenoid. push start and just a click from the cdi box. tried to jump solenoid and no start. I just spent hours running fresh grounds, putting a bilge in a bilge switch , yada yada yada..... what the hell can cause the soleniod to just click? the starter is not even clicking at all. Would it be a bad start relay? any help is welcome as i was hoping to ride this weekend.
I got another working box/starter but the 88 ( bad start issue) has been hacked and no longer has the quick connect, the good setup has the quick connect which means i gotta pull 2 magnetos just to swap back over to quick connects.
