WFO Speedracer
- Alabama
I have run across what I believe may possibly be a smoking deal on two part foam, I sent in a query to see what weight this foam would be equal to for our application. Two part foam is two part foam is two part foam, the difference is in the weight and expansion rate of the foam, the higher the rate of expansion the less the foam density will be, this can be adjusted in pour foam by adding minute amounts of water to the foam, The system I am posting about is in spray form so there will be no adjustment possible.
http://www.amazon.com/Dow-Chemical-308900-Froth-Pak-Sealant/dp/B0018AKMBS
