Difference between Blowsion & UMI steering system???
UK
Hi All,
I'm after a steering system for racing on my 08 SJ.
I want a -1 turnplate so will buy the blowsion one.
I was going to buy the UMI steering system but looking at the Blowsion website theor steering system looks almost identical with the bearing set-up etc.
Can anyone tell me the pro's & con's of either?
If the blowsion is as good as the UMI then this will work out cheaper as it comes with the -1 tunplate.
Thanks in advance.​
I have the Blowsion setup on both of my skis. Both of these steering kits require maintenance. Dont turn your back on it or it may cause you to miss a ride.
UK
Thanks, I understand that from having UMI previously, just wondering how the Blowsion kit differs if at all from the UMI?
