Differences in SN mid-shafts
Cannibal
Tasty Human
Summit Lake, WA
Just found out my 92 mid-shaft will not fit my 'new' 94 hull. So, what year range do I need a donor from? Will RN shafts fit?
Also, does anyone know of any other things they changed from 92-94 that I might run into swapping everything over (I mean everything).
Thanks,
Steve
if you just need the shaft then press them out and switch as they are the same. The bearing housings are different between 90-93 and 94-07 (if I remember correctly).
Adam
Cannibal
Tasty Human
Summit Lake, WA
Ya, it's the housing that is different. I only have a mid-shaft from my 92, so I need a replacement. So any housing will work from 94 to 07? Sweet.
Thanks
