- Home of the Steelers!
Blaster peeps,
Plan on making my own gas spring hood lift kit. I've determined the 20" expanded and 12" compressed (8" travel) gas springs are what I need, but I haven't figured out what compression weight to choose. Options are 20, 30, 40, 50, 60, 90 & 120Lbs.
I was thinking two 20Lbs gas springs would be appropriate. Thoughts? Also, if you install two 20Lbs gas springs do you really have 40Lbs of holding force (is it additive)?
Thanks in advance.
Thanks in advance.
