DJR Engine Braces - 6 Engine Mount Kit - DIY Kit for Yamaha Superjet Rickter & Aftermarket Hulls
http://djrltd.com/shopjetskiparts/d...for-yamaha-superjet-rickter-aftermarket-hulls
DJR Engine Braces
The part all of you freeriders have been waiting for! Forget engine keepers which last 5 minutes before bending. Forget rock hard, aftermarket engine mounts that make your ski feel like you are riding a washing machine with a brick inside...
DJR engine braces mount to your OEM Yamaha engine bed plates, allowing you to use an additional 2 engine mounts to support your engine and spread the load. Say goodbye to vibration, and hello to silky smooth engine revving.
For most aftermarket hull applications, including Rickter, simply mount these to your baseplates in the hull, and then drill and tap through your 2 additional engine mounts once into position into the mounting plates in the base of your hull. M6 tap is required to install onto bed plates. Stainless hardware provided.
Mount for right hand bed plate is slotted to make for an easier install.
For hulls without a large metal base plate like Rickter to mount your engine mounts to (such as Superjet), fibreglass or carbon mountings can be made up to support them with simple composite skills.
For custom colours, please allow extra time for delivery.
Price - £85 ($105)
We accept USD payments.
Taking orders now - email sales@djrltd.com
