does a type 4 need a flxible area???
does a type 4 pipe need a flexible joint where the silicone coupler goes? would it be possible to have an aluminum 2 piece clamp that holds the two sections together. maybe withe some high temp silicone sealant on the seams and where it fits to the 2 parts of the pipe. doesn't the riva make a pipe that bolts solid at that joint? i could fairly easily machine a nice clamp at work that would make it a fixed joint.
Ohio
Bwaaaaaaaa at you two!! LMAO! :biggrin:
You know what needs to be done. You have the cylinders and the pistons...give them to Korns guy and ORDER A B PIPE FROM FACTORY TONIGHT! Run with your carbs and then order some carbs from Supertune this winter.....or NOW! Its only money. We have all already been sold by our government as batteries for society so whatever little we can spend on skis is a plus!:grumble:
